purpose of emergency brake?
- Has thanked: 1 time
- Been thanked: 10 times
Hi, since the e.brake contracts transmission it seems to only work if trans is in gear. Is there a way to use it for parking wiyth trans in neutral?
- Has thanked: 149 times
- Been thanked: 310 times
Re: purpose of emergency brake?
I have a rough idea of how it works.
I would use it in gear personally, but the brake drum on the tail shaft, is designed to lock onto the tail shaft, so if its not in gear and handbrakes on, the brake lining are, should be jammed against the tail shaft drum,
- Has thanked: 97 times
- Been thanked: 568 times
The Hand Brake should work, hold the vehicle in place, with the transmission in neutral. If it does not then you either need to adjust the brake or replace the linings. The linings go bad pretty fast if there is an oil leak and it gets on the linings, which it usually does.
- Has thanked: 12 times
- Been thanked: 36 times
jwgreen wrote:The Hand Brake should work, hold the vehicle in place, with the transmission in neutral. If it does not then you either need to adjust the brake or replace the linings. The linings go bad pretty fast if there is an oil leak and it gets on the linings, which it usually does.
of if you leave the handbrake on, while driving and don't notice it till you smell something odd. don't ask how i know
1967 SPL 1600
2013 Nissan Rogue
2001 Nissan Sentra SE R
2013 Nissan Rogue
- Has thanked: 6028 times
- Been thanked: 1607 times
A true Patrol owner will suffer from this sooner or later! I'm with you.sleepyzzz wrote: or if you leave the handbrake on, while driving and don't notice it till you smell something odd. don't ask how i know
Thanks guys, it was just out of adjustment. I turned the main linkage rod several turns and now the ebrake works in neutral. Cool
- Has thanked: 7741 times
- Been thanked: 2482 times
Here are the instructions for adjusting the hand brake. There are 3 separate adjustments.
