Excellent information Ian.
I hope we can still get those synchro rings. For me, these rings are the weakest link in the Patrol. They are not up to par for their task, and wear rapidly, specially if you want to shift fast between gears. I used to get less that 20k miles on a set
The repair that member
robs30m in New Zealand did is outstanding. However it requires an expert welder and even better mechanical skills to put the right shape on the 3 prongs (?).
Also, member
Pancho has tried some rings from Colombia. He thinks they're made over there since he had mixed results with them. He was also able to source the original ones, but that was 3 years ago.
