67 Patrol in Utah
Lurker
Lurker
67 Patrol in Utah
Post by Averyboringguy »
Hello,
I bought a 67 Patrol about a month ago. I have been lurking on this forum getting some insight into what I have gotten myself into. The Patrol is in okay condition. I bought it from a guy who had let it sit for three years. He got it from a friend who had tore into it a bit. There is basically no wiring, no radiator, no coil, no fuel lines, etc so I haven't been able to fire it up yet. The passenger front hub was torn apart when I got it. The wheel was loose on the hub. I took it apart and found that the spacers were gone and it is missing one of the spindle nuts. I tried to find the parts, but they were in AUS and were more than i wanted to spend just to get it rolling. My dad is a machinist so I took the driver's side apart and had him copy the spacers i needed and got it rolling on all four wheels. (I am still looking for the second spindle nut.) At least one of the brake lines is cut and they are all disconnected. I have not torn into the wheel cylinders yet, but the pads look okay. There also was no front bumper, so I made a simple one to put the tow bar on. I will make some modifications to this eventually too.
My plan is to take it apart, cut out and replace the rusted parts of the panels, probably coat the underside and inside of the tub with a liner, repaint the body (probably the same blue/white colors), clean up and coat the frame and put it back together, paint the engine, etc... I am hoping the drive train is in decent condition and wont require rebuilding yet. Really what I want is a good ol' reliable rig that can go a good amount of places and have fun with.
Things I would like to replace first to get it running: (if you happen to have any of these let me know! :D )
-Radiator (I am losing hope at finding an original one and have found this aluminum one that seems like it will fit http://www.summitracing.com/parts/sum-380419)
-Coil (I am wondering if the Pertronix 45,000 volt coil would work with the waterproof distributor or if it is too much?)
-Spindle nut (as far as i can tell it is a M45x1.5, but i haven't found a replacement yet.)
-Crank pulley nut (not sure why that is gone, but I haven't been able to locate a replacement yet.)
Things to do before it is drivable:
-Brake lines
-Front passenger wheel brake cylinders
-Generator rebuilt
-Run Wiring
-Front blinkers and rear tails (thinking possibly going with LEDs 2" or 3" rounds. possibly http://www.amazon.com/Round-Surface-Mou ... =pd_ybh_22)
-New passenger door hinges (both were broken when I got it, but i was able to drill out and put a new pin in one of them. the other is completely broken.)
-Front seats reupholstered
-Get it registered (it was registered here in Utah in 2010**, but the guy i bought it from did not have a title. I am hoping i can submit for a duplicate with my bill of sale.)
** There is a sticker on the back that says it was sold from a Nissan dealer here in Utah. I'll have to do more research about that.
I'm sure I am forgetting a lot of other things but those are the basics. I would love some input about replacement parts and upgrades I can make as I go.
Some questions I have are:
1. Do Chevy 6 x 5.5 wheels fit over the hubs? I found a set of four wheels and tires for a good deal but am not sure if they will fit.
2. How are the two brake cylinders tied together? Does the main line come into the top cylinder, then another line runs to the bottom one?
3. Is there a diagram/pics for routing the radiator hoses with the heater core?
I think I got a great deal on this beast(a lot less than $1000) and I am really excited to start working. We are about to move so this has been put on the back burner, however, I have lots of ideas and plans and hope to get her going soon. I am sure I will be posting more and asking lots of questions when the work starts.
Thanks!
-Phil
Has thanked: 351 times
Been thanked: 301 times
Re: 67 Patrol in Utah
Post by mdawg4x4 »
Welcome to 60Patrol and the addiction.
Welcome!
Having a dad who's a machinist should come in very handy. :P
A guy near me (Arizona) had a nearly brand new NOS radiator and fan shroud as part of a huge list of parts he was selling several months back - not sure if he ever sold them or not, and as I recall, he was asking about the same amount that you could have a custom aluminum radiator made for, and if performance is more important to you than originality, then the aluminum radiator is the way to go, IMO - Aluminum conducts (dissipates) heat almost twice as efficiently as brass.
I will send you his name and number in a Private Message just in case you want to give him a try.
regarding the LED tail lights- I think these look a tad more original (if that's your goal):
http://www.amazon.com/Round-Surface-Mou ... VYTJJ6E0MJ
Has thanked: 7750 times
Been thanked: 2483 times
Welcome to 60Patrol! :text-welcomeconfetti: You've come to the right place for all of your Patrol questions. :D
You've taken on a quite ambitious project, to say the least. If you really love the Patrol, you might consider finding one in a little better condition and using this one as a parts donor. For what you paid, that's about right for a parts donor. It sounds as if many of the parts have been stripped off of it already. Just a thought. :think:
But we'll be glad to help you put this one back together. :D You can find the right radiator - more on that later - rather than the Summit Racing one. The Pertronix coil would be too much for the system, all you need is a simple 12v internal resistor coil, cheap at any auto parts store. And I actually came across a crank pulley nut yesterday and wondered why I had one loose.
The brake lines for the front wheel cylinders are fed from a splitter that the main line comes into. It sounds like you are missing the splitters. More parts stripped from this Patrol.
If one wheel cylinder is bad, you're better off rebuilding or replacing all of them. the wheel cylinders are a very weak link on the Patrol.
Your generator may be fine. Why do you suspect it needs rebuilding?
Yes, the Chevy 6 lug wheels will fit. You just want to check the offset. If they are too deep you'll have rubbing issues.
Worry about the heater hoses once you get the radiator. We can easily pick out one of many pics here that show the hoses. No problem. ;)
Here is your bonus answer: there is a guy in Utah that has 9 Patrols that he is selling or parting out. Check out this thread for his info: http://www.60patrol.com/forum/viewtopic ... res#p10174 . I'm sure you can find a radiator there, and maybe a whole bother front differential, and a lot of other stuff. I understand he's kind of hard to reach, and might be on vacation right now. But there is your gold mine. ;)
Please keep us posted on your progress.
Has thanked: 6031 times
Been thanked: 1610 times
Welcome to 60Patrol. You'll feel at home in not time here.
The radiator from Summit Racing has the inlet and outlet on the wrong side for the Patrol. They have this twin model radiator that's the same, only reversed:
http://www.summitracing.com/parts/sum-380319/overview/
The spacers that your dad has fabricated look awesome :clap: :clap: :clap: . Tell him to keep the measurements handy, since those parts are unobtanium. The bigger "spacer" is actually the seal race, so I guess that somebody else will need one sooner or later.
Good luck in your new project!
