Diameter of exhaust tube - manifold to muffler
zed
Has thanked: 203 times
Been thanked: 679 times
Post by zed »
I am trying to determine the correct diameter of exhaust tube - manifold to muffler for the USA configured Patrols.
Item 5 in photo
1387
So far, I have compiled the following:
Zed: 1.75"
Flaggoni: 2.25"
2869ral: 2.00" (checked on two original tubes)
If you have a moment, please take a measurement and post your findings.
Thanks,
Keith
Has thanked: 257 times
Been thanked: 270 times
Re: Diameter of exhaust tube - manifold to muffler
Post by Flaggoni »
I'll re measure..can't remember if that was measured original, or the size of my replacement muffler inlet meant to slip over something smaller.
Has thanked: 652 times
Been thanked: 632 times
Post by Coyote Patrol »
I have 2 originals, they both measure 2".
Has thanked: 6021 times
2869ral wrote:I have 2 originals, they both measure 2".
Final answer!
zed
Post by zed »
Ron,
How were you able to determine that your exhaust tubes were original? (The 1.75" tube on my 1969 also appears original, but I cannot determine if it was a replacement installed many years ago.)
Thanks,
Keith
zed wrote:Ron,
Thanks,
Keith
Hello Keith, first i should ask-are you measuring ID, or OD? Usually on exhaust pipe you measure the OD for the correct size. I cannot say for sure that Nissan used one specific size of exhaust pipe. But one of the OD measurements that i got was from my 66 Patrol that was in my family since new, and i know for sure it was original. The second measurement was from a 68 Patrol that i got from Papabear from Albuquerque a couple of years ago, and it looks and measures the same as my original. Not sure if that helps much, but thats how i came up with that. ;)
Post by Flaggoni »
The re measure of my 68ish header pipe shows 2" OD.
I believe it is original.
zed
Post by zed »
Houston, we have confirmation!
