Universal Joints
Original and compatible parts
Universal Joints
Does anyone know if these are a direct replacement our universal joints?? Says it fits NISSAN PATROL SAFARI Y60 1987-1997
http://www.amazon.com/Febest-Nissan-Uni ... B00C6MU140
Has thanked: 84 times
Been thanked: 327 times
Re: Universal Joints
Post by miller »
No won't fit. eBay AU has them
:banana-stoner: :character-jestercolor:
Has thanked: 6023 times
I have the following sources saved from some years ago.
Disclaimer: I have never bought or change any of the U-joints in my Patrol :twisted: . More than +300k miles.
For me this is a matter of careful engineering, coupled with good quality. The engine, rear arbor, and rear axle, are at a straight alignment under regular conditions, so the U-joints don't do any major job.
NEA-2-0053
http://www.northerndrivetrain.com/produ ... -0053.html
This site has a number different part #s according to car manufacturer.
Also this one:
Neapco # 2-0053 HD at AdvanceAutoParts w/ part # 2-0053
With the following specs:
Bearing Cap Diameter 1: 1.188"
Bearing Cap Diameter 2: 1.188"
Bearing Strap Kit: 1-0019 w/ 0.75 Bolt Length or 1-0020 w/ 1.50 Bolt
Bearing Type: Round-OSR
Lock-Up Dimension 1: 3.622"
Lock-Up Dimension 2: 3.622"
Lube Fitting: Yes
Manufacturer/Series: Spicer 1350
Precision 331 at O'Reilly, part # 331
Spicer 1350
Specs:
3.625" snap ring span,
1.188" cap diameter.
Outside snap ring.
Please note the slight difference between the Spicer and the Neapco: 3.625" vs 3.622"
Esteban wrote:I have the following sources saved from some years ago.
NEA-2-0053
Also this one:
Lube Fitting: Yes
Spicer 1350
Specs:
Outside snap ring.
Again Esteban, YOU ARE THE MAN!!!!! Mucho Gracias Amigo!!! :clap: :clap:
That's further than a one-way shot to the moon! On one set of U-joints! That does indicate that our Patrols are well engineered! ;-)
BTW, the the moon is about 238K miles from earth so you'd be about 1/3 of the way home if you went that route!
Has thanked: 652 times
Been thanked: 632 times
Post by Coyote Patrol »
Just don't stir the tanks! :lol:
