Parts
- Has thanked: 652 times
- Been thanked: 632 times
Parts
I have 3 rebuildable water pumps, 1 maybe 2 starters not sure if they need rebuilt, 2 cooling fans, a complete set of push rods, and 3 brake master cylinders that im rebuilding only 1 with a resevoir. Thought i would post these here before they go on Ebay.
- Has thanked: 646 times
- Been thanked: 1149 times
Re: Parts
I'd be interested in a starter... Mine seems slow so it would be comforting to have a spare
Re: Parts
Ok i will test them and let you know. Well 1 works just needs the shaft cleaned so the starter drive will throw. The other one doesnt work, i will pull this one apart and try to fix it, probably dirty brushes.faux40 wrote:I'd be interested in a starter... Mine seems slow so it would be comforting to have a spare
Re: Parts
Lovelace81 wrote:I may be interested in the brake master cylinders
Or is there a rebuild kit I should buy in stead
WELCOME to 60Patrol.com !!!!
There are 2 compatible rebuild kits that 2869ral has found during his research. Both part numbers (one is Oreilly, and one is NAPA) are listed in this thread:
http://www.60patrol.com/forum/viewtopic ... 7&start=15
If you have the tools to hone the master cylinder, and if you master is in good shape, then rebuilding is always an option.
But, before we go any further with your brakes, we will need to ask you to post a couple pictures of your Patrol
