Lubrication areas...
- Has thanked: 202 times
- Been thanked: 75 times
Has, or does anyone ever lubricate their starter and clutch/brake pedals? I always looked at the bearing on the starter but until I read the owners manual didn't know that you could simply push it down and drop oil in it!! It says to use motor oil.
It also shows the area to add oil to the water pump!
1966 Patrol
Instagram: we_lexplore
Re: Lubrication areas...
I looked but don't see the grease nipple on my water pump.
1966 Patrol
- Has thanked: 6017 times
Maybe the water pump was replaced at some point. The newer design pump is lubricated for life, has a totally different bearing and seal.
I've always lubricated the starter motor and also the pedals. Not as often as called for. Hey, thanks for the reminder.
The oldest Patrol with the mechanical linkage for the clutch was fitted with 26 grease zerks! Probably the most of any 4wd ever.
I better start buying my grease by the drum.
Funny you mention it! I have a '66 with a mechanical clutch and I had it up on the lift at work the other day and I thought I had got them all, until I climbed under it again today to find more that I missed by the levers to the transfer-case.Esteban wrote:The oldest Patrol with the mechanical linkage for the clutch was fitted with 26 grease zerks! Probably the most of any 4wd ever.
1966 Patrol
- Has thanked: 7706 times
The later water pumps, after about '65, didn't have the greasable bearing. So, there was no grease fitting for it.
Perfect, thanks! For some reason this thread doesn't give me the option to "thumbs-up" thank you!RiverPatrol wrote:The later water pumps, after about '65, didn't have the greasable bearing. So, there was no grease fitting for it.
1966 Patrol
- Has thanked: 646 times
- Been thanked: 1149 times
I've noticed this too -- Does anybody know why this is?offroadkid wrote:For some reason this thread doesn't give me the option to "thumbs-up" thank you!
faux40 wrote:I've noticed this too -- Does anybody know why this is?offroadkid wrote:For some reason this thread doesn't give me the option to "thumbs-up" thank you!
This is the first time I have seen this. It's only missing on my post, still there on everyone else's. Hmmm...
