Engine temperature???
- Has thanked: 23 times
- Been thanked: 21 times
Hi everyone, I have a question that would help me, someone knows what temperature should work the engine of a Nissan Patrol 1978. Thank you
Henry B.
Venezuela
Venezuela
- Has thanked: 6028 times
- Been thanked: 1607 times
Re: Engine temperature???
I'm guessing that you are normally with outside temperatures around 30°C (86°F), so please correct me if I'm wrong. In that case I will fit a 71°C (160°F) thermostat in the Patrol.
With that, the temperature reading in the panel should be around 85°C (185°F). Always use an antifreeze protection, no so much for that, but for the fact that they also raise the boiling point in the coolant, so less over-pressure in the system.
