Compatible Brake Drums
Has thanked: 173 times
Been thanked: 306 times
Post by Peter60 »
I have a 68 Patrol. I fitted new cylinders and shoes to the front. I thought I would have the front drums honed and cleaned up at the local brake shop.
They measured them and said they were oversize/too worn and there was nothing they could do.
So far I haven't been able to find any new drums for the G60 but could get some rear drums for a Y60 (I have no idea if they fit)
So are there any compatible front drums available for a G60?
Has thanked: 7690 times
Re: Compatible Brake Drums
None that I am aware of. Shouldn't be too hard to find a set of used ones.
Has thanked: 652 times
Been thanked: 632 times
Post by Coyote Patrol »
Ive heard that toyota pick up drums fit 1980s-early 90s not sure though i havnt tried myself. Im thinking the center hole may need to be open up some on the toyota. Good luck with this. Let us know what you find.
Post by Peter60 »
A recent post titled "Parts From Down Under" see http://www.60patrol.com/forum/viewtopic.php?f=24&t=3802 had brake linings with 6mm oversize.
So a couple of questions?
I think the drums are 292mm diameter. If these were honed out to 298mm would the oversize linings fit perfectly? Is there any downside?
Could a brake shop make some oversize linings - say 295mm to match honed out drums to 295mm?
Has thanked: 18 times
Been thanked: 14 times
Post by ctcruiser »
anything compatible around for this?
Post by Peter60 »
Nope. I didn't find any. I ended up just buying a few drums from a old parts G60.
