Oil pressure sender, what works?
Gnu
Been thanked: 8 times
Post by Gnu »
G'day everyone,
I'm trying to source a new oil pressure sender for my 76 resto project and would like to get the factory oil pressure gauge going but I'm struggling to find a listing on a new sender. Does anybody know of one or at least an ohm range that will work close enough with the factory gauge?
Cheers, Gnu
Has thanked: 7706 times
Re: Oil pressure sender, what works?
EBay seller schluderm used to have them. http://www.ebay.com/usr/schluderm?rt=nc I don't see that he has one listed right now though. You might contact him and see if he has one.
Gnu wrote:G'day everyone,
Cheers, Gnu
If the resistance is in the correct direction (e.g. more pressure = more resistance or vise versa... I can't remember which it is), then we can probably make a tiny circuit that will scale it to match the gauge. I'm happy to help with that.
Gnu
Post by Gnu »
Thanks guys, I think I'll run the gauge down to my local electronics guy and see if he can give me and ohm range it works through, then I might be lucky enough to find one close enough from another vehicle, if I can't get it spot on it's not the end of the world but the little details make a difference I think :D
Has thanked: 173 times
Been thanked: 306 times
Post by Peter60 »
Not sure if this is what you are looking for in ebay
http://www.ebay.com.au/itm/Fuelmiser-Oi ... 3cfd91d307
I don't know if it is for a light or actual gauge. There are a few on ebay with conflicting descriptions.
Gnu
Post by Gnu »
Peter60 wrote:Not sure if this is what you are looking for in ebay
Hi Peter60,
That listing is like all I've come up with so far but it's for a oil pressure light, they are just a simple pressure switch, the gauge senders are generally much bigger as they have a varible resester in them.
I spoke with the local electronics guy yesterday and he said if I bring the gauge in he can run a test and give me the working resestence range of the gauge, then it's a matter of trawling listings to find a sender as close as possible, he said if it were real critical he could build a small circuit to correct the range of a different sender. I Guess this is the same thing a you already suggested Faux40?? I'll up date results as I get around to it.
Thanks guys
