Front Wheel Cylinder Kit
- Has thanked: 13 times
- Been thanked: 23 times
In need of four (4) front wheel cylinder rebuild kits for a new project..... know these are hard to come by but hoping someone had some laying around. Thank you in advance.
- Has thanked: 7718 times
Re: Front Wheel Cylinder Kit
The wheel cylinders are cheap enough on eBay, it's hardly worth the effort to rebuild them. Here's the link: http://www.ebay.com/itm/261419018581?_t ... EBIDX%3AIT
- Has thanked: 173 times
- Been thanked: 306 times
I can recommend them. I ordered a set one day and they were delivered the next day. I live in Australia, so not sure about delivery to the US, but I assume they would be fairly quick.
- Been thanked: 3 times
I ordered a set for the front, shipped on 9/27 received them on 9/30 ... I was amazed by the express service !!
- Has thanked: 6022 times
They will fit. You'll have to double check the thread fitting, since Nissan changed to metric around 78. Not sure if the wheel cylinders were changed.
I believe NAPA can match the wheel cylinder but it's going to be metric, then you have to change all the junction blocks and master cylinder to fit the other end of the brake steel line , it's a chain reaction !! It's cheaper to buy them from down under ! Take RiverPatrol's advice, you'll be happy... I did .
