P40 waterpump on g60 P motor
Posted: Fri Oct 16, 2015 8:31 pm
by Gnu
Hi guys,
I'm trying to find out if a p40 waterpump will physically bolt up to the P motor, I understand they have their differences but I'm thinking if I can run a p40 waterpump, viscous coupling and fan (might need a custom pulley??) it would be a nice upgrade to the roaring steel fan. The main reason for all this is I need a new waterpump for my resto protect and cannot source one or even a kit anywhere in oz but p40 parts are still readly available.
Re: P40 waterpump on g60 P motor
Posted: Fri Oct 16, 2015 8:42 pm
Sorry, but it's completely different. Don't even try.
The front of the P40 engine is where the biggest changes are: different water pump, thermostat housing and timing chain components.
Posted: Sat Oct 17, 2015 7:46 am
by Gnu
Ok so the p40 pump itself regardless of everything else won't physically bolt to to P block?? Anyone else in Australia have any ideas for a new/reco P motor pump?
Posted: Mon Oct 19, 2015 7:03 am
by Peter60
See in this forum under "Parts From Down Under" (sorry I don't know how to link to it!).
There is a part list attached for G60 parts. They say they have a water pump - although a bit confusing as they say "G60" and "P40" in the entry.
Posted: Mon Oct 19, 2015 10:14 am
The water pump # is: 21010-C0626
also
21010-C4925 (which supersedes the above)
The repair kit for water pumps made after 1973 (not good for any USA Patrols) is: 21046-C0610
They list the repair kit at this site in Australia. The price is steep ($211.15) and don't know about availability.
http://www.alliedforklifts.com.au/index ... il=&pf=596
Please report any findings.
Posted: Wed Oct 21, 2015 3:28 am
by Gnu
Thanks for your help guys, at this stage I haven't done any good on these leads but will keep trying, after a bit of mucking around I can confirm that the p40 pump will not bolt to the P block as was suggested but I think if someone was extra desperate I think an adaptor plate could be a possible option. At this stage i think I'll be sending this one to Melbourne for a reco. I'll keep you updated
