68 and up left side window regulator
Parts for sale, or free
Has thanked: 15 times
Been thanked: 23 times
Post by weasel451 »
This is a 68 and up LH regulator. I purchased by mistake for my 67 and cannot use it. Anyone have a correct reg for trade? Otherwise, will sell or trade. Thanks
Has thanked: 652 times
Been thanked: 632 times
Re: Left side window regulator
Post by Coyote Patrol »
I probably have one to trade, i will let you know here shortly today. :D
Re: 68 and up left side window regulator
Sorry, i forgot to look my brain is scrambled! Anyway im pretty sure i have one if you still need it, if i dont forget again i will check tomorrow when i get home from work. :D
I found 2 LH regulators, 1 is stripped badly and the other has several bad teeth. What is wrong with your original? Or do you have one?
Post by weasel451 »
Bummer...no, I don't have one. My patrol was pretty well stripped when I bought it so a lot of the basic stuff I've been trying to locate. I'm down to the last few items and this is one of the big ones. Thanks Ron...let me know if you find one I can use...have a good one, darren
A couple of times I've fixed my LH regulator due to stripped teeth on the arm portion (see the picture below).
- weld some material to fill the broken teeth area
- grind the weld until the surface is flat, and the overall curvature outside is good
- find a used regulator of another car, and cut a section that has the teeth. You need to find one that has roughly the same pitch, and don't care about the curvature. This is going to be a template and you'll be adjusting teeth by teeth.
- attach the template to your regulator and secure with locking pliers, and one by one, proceed to grind again the missing teeth.
You might end up with some rough spots when you operate, but it will do the trick. Put a lot of grease! Good to go for 10 more years!
The picture that follows is from my regulator. The welding is pitiful, so spare the comments :twisted: :laughing-rolling: :laughing-rolling:
Post by weasel451 »
Actually, I would say that's pretty impressive, Esteban. Thanks for detailing the process. If that's what it comes down to doing, I'd better brush up on my welding skills. Thanks, Darren
Has thanked: 33 times
Been thanked: 35 times
Post by 250g60 »
How different are the regulators, can you re-drill your door/regulator mounting holes to make it work
Regulators and their location in the door are totally different so it's not a clean proposition. Then you'll fase the problem on the other door as well.
Esteban wrote:A couple of times I've fixed my LH regulator due to stripped teeth on the arm portion (see the picture below).
You are the man, Esteban... 8-)
This is exactly how I was planning to fix my regulators, as well - The only other info I would add for anyone who wants to attempt to weld their window regulator teeth is: Be careful- That is super-soft mild steel, so don't hit it with a lot of current - use very low settings
and, for anyone who can't weld, and is looking for an alternative method - If you have a $25 MAP torch, then you might be able to build the teeth back up with Muggy Weld Super Alloy-1:
http://muggyweld.com/super-alloy-1
This stuff sticks well, cools hard, and is grindable and shape-able after it cools. I can't guarantee that the teeth would last as long as welding them with steel rod or wire, but I can testify that muggy weld's entire line of brazing alloys are VERY AWESOME products.... very expensive, but VERY awesome... 8-)
