Sway Bar "D" Bushes
Has thanked: 173 times
Been thanked: 306 times
Sway Bar "D" Bushes
Post by Peter60 »
I'm having problems finding correct D Bushes.
I ordered Nolathane part no 42075 but the inside diameter was 23mm but my 1868 G60 has 20mm sway bars. The other dimensions of the D Bushed were perfect!
See http://www.nolathane.com.au/product_det ... 75&sq=6753
Both front and rear D bushes seems to be the same size.
I have lodged a request with Nolathane.
Any advice on where I can find the correct part (in Australia of possible)?
Has thanked: 7707 times
Re: Sway Bar "D" Bushes
You might try ordering the stock ones from Nissan. The part number is 54613-44000. It's been a few years, but I was able to get them from Nissan before.
Has thanked: 149 times
Been thanked: 310 times
Post by G60michael »
Hi Pete, I Run Nolathane in mine, they matched the original ones that came out of it, mines a 66 model so im not to sure if they changed Sway bar's overtime.
Ill Try and Get some Numbers from our Stock list books at work, cheers mike
Post by Peter60 »
Andy from Nolathane responded promptly:
" You can use the Nolathane (42931) Saddles, and the (42920G) bush kit suits 20mm Swaybars."
Brushes about $30 a pair and Saddles about $40 a pair - both on ebay. Its a bit easier and faster than going to order them from Nissan.
Can someone confirm the sway bars are actually 20mm. It a bit hard to measure accurately with all the rust and grime.
Has thanked: 42 times
Been thanked: 73 times
Post by EricB »
Just as an FYI
I called my local dealer here in SoCal, I called CourtesyNissan in TX, and one of the big NissanParts websites and 54613-44000 is now NLA from the mfg ...
Has thanked: 131 times
Been thanked: 147 times
Post by rjiggy »
I recently ordered a full set from Amayama Trading
https://www.amayama.com/en/search?q=54613-44000++
They were cheap, $3.38 each and shipping was reasonable. I had a total of about $90 in parts and about $20 in shipping from Japan. It took a couple of weeks to get here. I was very satisfied with the whole deal. I also ordered two throw out bearings including shipping from UAE for about $50. They arrived within a day of the parts from Japan.
