Oil pan bolts
- Has thanked: 233 times
- Been thanked: 165 times
Oil pan bolts
The fasteners on my oil pan were so mixed up I have no idea what is right. Is it flat washer and bolt or flat washer, lock washer then bolt?
1967 Patrol
2017 Toyota Tacoma
1968 Camaro
1968 Disneyland Autopia Car
2017 Toyota Tacoma
1968 Camaro
- Has thanked: 131 times
- Been thanked: 147 times
Re: Oil pan bolts
Pdub,
According to the parts manual I have there are lock washers only. It also shows (3) 5/16" studs, (2) 5/16" bolts of one length, and (17) 5/16" bolts of another length. The part description does not give the length of the bolts or studs, and the
exploded view does not define all of the locations for each type. Mine had a hodge podge of 5/16" bolts in it, no studs.
I hope this helps.
I hope this helps.
Re: Oil pan bolts
Studs for an oil pan? Never seen that before. Yea mine was like yours no studs. Ok, I guess bolts and lock washers it is.
1967 Patrol
2017 Toyota Tacoma
1968 Camaro
2017 Toyota Tacoma
1968 Camaro
- Has thanked: 7703 times
Re: Oil pan bolts
I've never come across studs for the oil pan, I think it's just bolts. I don't even remember there being lock washers, but there might have been.
- Has thanked: 6017 times
- Been thanked: 1601 times
Re: Oil pan bolts
I've always had bolts and lock washers. The two longer bolts go through the exhaust pipe support. You have to be careful on not over-tightening these bolts to prevent damage to the cork gasket. Use of a torque wrench is a must, since the torque is very low, at 2.9-4.3 ft-lb (3.9-5.9 N.m).rjiggy wrote:Pdub,
I hope this helps.
Personally, I got rid of the cork gasket more than 20 years ago and only use silicone compound and not even pay attention to the torque.
Re: Oil pan bolts
LOL
Exhaust pipe support. Just another thing that probably got ripped off my patrol by a rock in the past. Like the oil pan skid plate.
1967 Patrol
2017 Toyota Tacoma
1968 Camaro
2017 Toyota Tacoma
1968 Camaro
