Spark Plug
Been thanked: 10 times
Spark Plug
Post by chrisvoinche »
I am looking for the correct spark plug to put in my 1965 Nissan Patrol? Searched the board, but no luck. Can someone help?
Chris
zed
Has thanked: 203 times
Been thanked: 679 times
Re: Spark Plug
Post by zed »
Stock Number 1034 NGK BP7ES - Spark Plugs
O’Reillys Part number 1034 $2.49
Autozone $2.49
Pepboys $2.29
NGK BPR7ES
O’Reillys Part number 3785 $1.69
Hotter plug - NGK BP6ES
Re: Spark Plug
Thanks Zed!! Do you have numbers for Plug wires-(my truck has the waterproof caps on it), and points & condenser?
Re: Spark Plug
I am also looking for a soft top frame for my patrol. Let me know if anyone has one they want to part with.
Chris
Has thanked: 27 times
Been thanked: 81 times
Re: Spark Plug
Post by soft60 »
chrisvoinche wrote:Thanks Zed!! Do you have numbers for Plug wires-(my truck has the waterproof caps on it), and points & condenser?
Did you ever get part numbers for the plug wires and coil wire?
And does anyone have replacement part numbers or a recommended source for plug+coil wires to fit the Helmar Dizzy - I am replacing my WP and cannot find a set.
And finally - is there anyone who rebuilds the WP dizzy? I'd like to have it on the shelf in good working order for reinstallation - either if I get serious about restoration to original or if I ever sell it (perish the thought).
Thanks in advance
Soft60
Has thanked: 7718 times
Re: Spark Plug
The part number for plug wires is 22450-80029. They aren't specific for the WP distributor because they have the connectors on the ends. The connecters get cut off to use them with the WP distributor cap.
I don't know why they wouldn't work for the Helmar distributor, if they are still available. Actually I would think that pretty much any plug wires should work for the Helmar. Plug wires are usually universal.
Re: Spark Plug
Post by soft60 »
Thanks, River. I will look for those wires.
For now, I bought a wire set for an early straight six Mustang and the lengths worked out well, except that the coil wire was to short. I bought it separately.
The Helmar swap made a BIG difference. The WP distributor appears to have been the cause of my misfire issues, likely because of a worn bushing and maybe the advance, too. The truck runs like a watch and with the new exhaust, sounds a lot less tractor-like.
Does anyone know whether the WP can be rebuilt? I'd really like to keep the truck as close to stock as practical.
Thanks
David
Re: Spark Plug
Good to hear it's running well.
I don't recall anyone having their WP distributor rebuilt recently. I know the vacuum advance can be rebuilt. There is a place in Washington State that does it. See this post in the archives: http://www.60patrol.com/forum/viewtopic ... 289&p=7185
Re: Spark Plug
I had mine rebuilt and converted to electronic ignition here. They are a little pricey as I recall.
http://www.philbingroup.com/philbin_rebuilt.htm
Has thanked: 87 times
Been thanked: 207 times
Re: Spark Plug
Post by rrodriguezsal »
chrisvoinche wrote:I am also looking for a soft top frame for my patrol. Let me know if anyone has one they want to part with.
Chris
Hi. I am in Colombia and I have taken advantage of my body expert free time to make some Frame for soft top reproduction. Please see pictures. I am not sure how expensive is ship it from Bogota Colombia to USA. Maybe you can come a couple days for vacations and carry it. Windshield not included. It is to assembly all parts and test.
