Feeler- 69 engine, drive train, axles, suspension
Posted: Tue May 17, 2016 2:30 am
Hello, new to the forum and a new owner of a 1969 hardtop. Going a different route with the build on this one and will have quite a few parts available soon. After a quick tune-up I've been daily driving the Patrol the past few days. Happy to take pictures and video of everything running and driving prior to selling any of it. I don't intend on digging iinto the build for a few months but figured I'd get some feeler out on parts that will be available.
Engine- Runs great, No smoke, waterproof dizzy, new plugs coil and wires. Holy carb that says it was rebuilt in 2012. The carb could use a little bit of work. Haven't done a compression test but willing to do so and document it. Top end is pretty clean. Valve cover leaks a bit and rear main has a few dribbles.
3 speed trans and transfer case- 1st synchros are a bit rough. Other than that it shifts smooth and drives good
PTO and old school Warn winch. No winch cable.
Front and rear driveshafts
Front and rear axles and suspension
Front 60/40 and rear jump seats. Need new foam and covered.
Front seatbelts. In fair need to be cleaned codition
Gas tank- hadn't checked the condition inside
That's a start. Basically I'm keeping the body land frame
