U JOINTS
Original and compatible parts
Has thanked: 233 times
Been thanked: 165 times
U JOINTS
Post by pdub »
Anyone have a source for U joints. I don't see any in the compatible parts list. O'reilly has a spicer joint for $35.00 ea. Pretty costly when you need 8. Any help would be much appreciated. :D
1967 Patrol
2017 Toyota Tacoma
1968 Camaro
1968 Disneyland Autopia Car
Has thanked: 6018 times
Re: U JOINTS
I have the following information saved from some years ago. I haven't used them but other member have.
Neapco # 2-0053 HD
This one is greasable. Can be find at Northern Drivetrain.
http://www.northerndrivetrain.com/produ ... -0053.html
Bearing Cap Diameter 1: 1.188"
Bearing Cap Diameter 2: 1.188"
Bearing Strap Kit: 1-0019 w/ 0.75 Bolt Length or 1-0020 w/ 1.50 Bolt
Bearing Type: Round-OSR
Lock-Up Dimension 1: 3.622"
Lock-Up Dimension 2: 3.622"
Lube Fitting: Yes
Manufacturer/Series: Spicer 1350
At O'Reilly Auto Parts
http://www.oreillyauto.com/site/c/detai ... eyword=331
This other site has another U Joint that can be installed when greater angles are desired:
http://www.4xshaft.com/Super-Flex.html#_blank
Please post some pictures when you change yours.
