Also on the prowl for an original, or compatible, oil pressure sending unit that screws into the drivers side of the block. Thanks in advance!
Don
Oil Pressure Sending Unit
- Has thanked: 652 times
- Been thanked: 632 times
Re: Oil Pressure Sending Unit
I had an extra floating around, i will look for it.DMC Z wrote:Also on the prowl for an original, or compatible, oil pressure sending unit that screws into the drivers side of the block. Thanks in advance!
Don
Well i havnt found it yet. I know i stashed it somewhere. Have you found one yet? do i still need to locate this one for you?2869ral wrote:I had an extra floating around, i will look for it.DMC Z wrote:Also on the prowl for an original, or compatible, oil pressure sending unit that screws into the drivers side of the block. Thanks in advance!
Don
