alternator voltage regulator
Posted: Thu Sep 22, 2016 6:54 am
by Wobbley69
Hi
Is there any reason why the regulator has the connections for an alternator dash light but never wired up?
Re: alternator voltage regulator
Posted: Thu Sep 22, 2016 9:44 am
Can you post a picture? My first guess is that whoever installed that alternator just didn't do it. The stock alternator doesn't have a dash light.
Posted: Fri Sep 23, 2016 8:29 am
by Wobbley69
Well it now has a dash light for the regulator/alternator working. Utilising a forgoten feature.
Posted: Fri Sep 23, 2016 11:34 am
Glad you sorted out.
The easy answer is that most Nissan in the late 60s and 70s needed only around 35 amp alternators. So they fitted the same regulator to all the models, changing probably the decal and the part # (maybe) Since the Patrol always had the amp-meter, they must have thought that the light was not needed.
You can adapt the same regulator to alternators ranging in power from 35 to 80 amps easily, since the only control the voltage going into the stator. The generator regulator on the other hand, handles the current output, so it should match closely the rating.
Posted: Sat Sep 24, 2016 12:20 am
by Wobbley69
This is a 78 patrol. I have upgraded the alternator to one off an p40 engined mq patrol and the ammeter connection to the battery just wasnt cutting it any more in terms of getting the charge through and has been bypassed.
