Hi all
What section weatherstrip are you using for the vertical flange of the left side rear door (the flange that the right side rear door closes against) ?
I found these over at mcmaster.com http://www.mcmaster.com/#trim-seals/=14o7e63
Specifically this one would probably work well: http://www.mcmaster.com/#1120a221/=14o7fcg
There's next to nothing left of my original one ...
Wanted to get your $0.02 ...
Thank you
-e
Rear Door Weatherstrip Section ?
- Has thanked: 42 times
- Been thanked: 73 times
- Has thanked: 7693 times
Re: Rear Door Weatherstrip Section ?
That would certainly work. In the past, I have simply used something that works.
