Valves for a p engine
Been thanked: 4 times
Post by Aus60 »
Hi all just wondering where I could get an inlet and exaust valve, there is a leak on the #5 cylinder and I'm suspecting burnt valve. or would I need stem seals aswell? Cheeres
Has thanked: 7743 times
Been thanked: 2482 times
Re: Valves for a p engine
You might find that all it needs is a valve grind. The valves are pretty meaty on these engines, and you can grind quite a bit and still be within tolerance.
What RP said or otherwise Motorpower Inc usually has them.
Has thanked: 173 times
Been thanked: 306 times
Post by Peter60 »
I have a couple of spares. They were in a box of parts that came with my patrol. I'm not sure of their condition.
My G60 was converted to run on LPG and I assume the valves were replaced as LPG runs hotter then petrol. However they may have suffered the same problem as yours before being replaced.
I will dig them out if you are interested.
However I would try a valve grind first as recommended below, that sounds the easiest.
Post by Aus60 »
Cheeres everyone. I'll pull the head and see what I'm dealing with. To stop this happening do I just need to put Lead additive into it?
If the engine was run on LP previously, that could be the cause. I don't find it necessary to add lead myself. That's usually needed for high performance engines.
