Water Pump Zerk Fitting Thread Size
Has thanked: 85 times
Been thanked: 97 times
Post by ShowMePatrol »
Good Sunday morning! I was wondering if anyone knew what size thread the water pump zerk fitting is? The zerk fitting was missing from my WP after I received it back from a recent rebuild.
Thanks!
ShowMe
Re: Water Pump Zerk Fitting Thread Size
Is it possible that a sealed bearing was used during the rebuild so the zerk wasn't replaced? I think that may be the case. I just don't like having an open hole at the top of the water pump.
Has thanked: 7703 times
Yes, they most likely used a sealed bearing. It was only the very early waterpumps that had the Siri fitting for greasing, the later ones, after about '65, came with sealed bearings. Sounds like it's good to go.
Thanks!!!
Has thanked: 6017 times
Been thanked: 1601 times
Without knowing what bearing was installed, I will put the Zerk fitting there. You might have to do a couple of trials to find the right one.
