BOLT ON brake master
Posted: Mon Dec 26, 2016 2:14 pm
Hi all
I thought I read in someone's brake / build thread that the Australian Protex master cylinder that is sold by Greg at 4WD in Australia was bolt-on?
Well it isn't, I just received one and the center to center dim on the flange bolt holes is approx 60mm.
The center to center dim on the firewall studs for the stock single circuit MC is approx 65mm.
Unlike the Wilwood MC, there is SOME meat in the Australian MC to open up the holes, but not much.
I measured the Aus MC and there's 5mm between the OD of the top mounting hole and the edge of the flange,
and only 4.5mm between the OD of the bottom mounting hole and the edge of the flange for the bottom hole.
Do-able yes, but admittedly that doesn't leave a lot of meat...
I just wanted to put this out there.
Also (not that it matters) the outputs for the brake hard lines are metric FYI
So is getting a old Chevy truck MC like what Rob came up with the only true BOLT ON MC ?
