I need a front brake cylinder
Posted: Mon Jan 30, 2017 12:21 pm
by weasel451
I installed all four cylinders up front last summer and really didn't drive around much at all...my front leaf springs were shot. Anyway, one of the left side cylinders decided to purge brake fluid through the seal. The connections and lines aren't leaking. Anyone have a spare cylinder? Thanks.
Re: I need a front brake cylinder
Posted: Tue Jan 31, 2017 11:05 am
If they're that new, it's possible that you could just clean it up and it will be fine. I've had that happen before. You could just remove the piston and clean it up as well as the inside of the cylinder. Clean the brake fluid off of the seals and put it back together. Give it a shot before you spend the bucks for another cylinder.
Posted: Tue Jan 31, 2017 4:55 pm
by weasel451
I'll do it. Thanks.
Posted: Tue Jan 31, 2017 6:17 pm
by jwgreen
If you find that a seal is nicked I believe I have some spare that you could replace it with if needed.
Posted: Wed Feb 01, 2017 6:24 am
by weasel451
Thanks Justin. I'll get on it in the next few days and let you know. Appreciate the help!
