Rubber Cap for Brake Master Cylinder?
Posted: Thu Feb 16, 2017 8:00 am
by L60Boerne
I bought four of these thinking I could cut a hole in them and use them for the rubber gasket surrounding the fuel intake.
Before I ruin them I thought I'd see if anyone really needed them. The seller in Kuwait said they were for a G60 Patrol.
First, what is their intended purpose and does anyone need them for that purpose. I have four.
Regards,
Re: Rubber Cap for Brake Master Cylinder?
Posted: Thu Feb 16, 2017 8:51 am
L60Boerne wrote:I bought four of these thinking I could cut a hole in them and use them for the rubber gasket surrounding the fuel intake.
Regards,
That is indeed the rubber cap for the brake master cylinder for all Patrols up to early 1970. I'm sure it will interest some of the members, since over time, they expand a little bit and become mushy.
Posted: Thu Feb 16, 2017 11:26 am
Please don't cut them up! I will trade you for the ring around the fuel intake.
Posted: Thu Feb 16, 2017 3:15 pm
by r1lark
L60Boerne, I sure could use one of them for my master cylinder. The original has morphed into a gooey rubbery mess.
Posted: Thu Feb 16, 2017 7:55 pm
by L60Boerne
Leslie, You get one. I would appreciate that rubber gasket in return. It is the black rubber piece you see while trying to put the fuel nozzle in the fuel intake. I'll trade two for two, if you have two. Also, i'll give you as many as you need, saving one for Paul.
Paul, you have one coming your way too. Just send me your address.
Patrolling with passion,
PS. check out this super cool fuel tank mat .....
www.holley.com/products/fuel_systems/hy ... 106...this solves a huge problem. I've got some coming.
Youtube
https://youtu.be/N_jsSPRUTSA
Posted: Thu Feb 16, 2017 8:11 pm
by Coyote Patrol
That fuel tank sock is cool!
Posted: Fri Feb 17, 2017 7:35 am
by r1lark
David, I sent you a PM with my address. Thanks!
Watched the video on the fuel pickup 'mat'. That is simply amazing. And there is so much filtering capability (surface area) with that thing, it's crazy!
Posted: Fri Feb 17, 2017 10:49 am
I can trade 2 for 2, I'll take 3 if they're available.
Posted: Sat Feb 18, 2017 6:44 am
by L60Boerne
Leslie,
Your two or three will be mailed today.
Paul, yours will be mailed today as well.
Regards,
David
