Gear oil for diffs and transmission
Has thanked: 1 time
Been thanked: 51 times
I'm changing all the fluids on my patrol before I run it much for the first run. I've done the coolant and the engine oil. I've drained the diffs and am going to drain the transmission and transfer case . I see the chart that river sent me from Esso calls for 90 ep oil for all gear applications but all I can seem to find is 80w90. I'm assuming this is proper as well for the diffs and trains?
Has thanked: 6023 times
Been thanked: 1605 times
Re: Gear oil for diffs and transmission
Yes. I've been using only that for diffs and tranny. I don't even bother with synthetics types here.
Has thanked: 514 times
Been thanked: 631 times
Post by rdarnell »
I got a 5 gallon pail of GL-4 when i was doing my FJ55, the current GL-5 has higher levels of EP additive that is corrosive to the brass parts. Will do the same with my patrols. I think my father runs just a straight weight mineral oil in his CJ3 Jeep.
Has thanked: 1 time
Sweet. I picked up a jug of 80w90 , is rated for gl4 and 5. I made a transfer pump out of a garden sprayer and some tubing. I'll post a pic later
Has thanked: 1 time
So here is the transfer pump for the gear oil that I made from a 1 gallon garden sprayer some clear tubing and a ball valve. I used a piston type before but found it leaked a lot and made a mess. I was able to pump it up and work on other things while it filled the diffs and the transfer case. I have a very dumb question, where is the fill plug on the transmission? I found the dip stick but it is seized so I am soaking it.
mattmctree@gmail.com wrote: I have a very dumb question, where is the fill plug on the transmission? I found the dip stick but it is seized so I am soaking it.
Not at all. Unfortunately the dip stick plug also acts as the fill plug. So be careful not to damage it, specially trying to unscrew it by the handle.
I modified on mine the lateral cover years ago, and installed a fill plug there. It also acts as an overfill check. I posted a picture here some years ago. I will try to find the link.
