where to get seals and gaskets for trans and diffs
Has thanked: 1 time
Been thanked: 51 times
From sitting for so long most of my seals on my transfer case tranny and diffs are leaking. Does anyone have part numbers and sources for seals
Has thanked: 257 times
Been thanked: 270 times
Re: where to get seals and gaskets for trans and diffs
Post by Flaggoni »
The same seal is used in 4 places; both xfer case outputs, and both pinion seals.
I googled the number from the parts manual and had no trouble locating sources. (Three years ago)
Has thanked: 1 time
The parts manual I have I from 65 have the numbers changed?
Has thanked: 6021 times
mattmctree@gmail.com wrote:The parts manual I have I from 65 have the numbers changed?
No. They've remained the same until the last parts cataloge of 1980: 38189-44000
Regarding the gaskets, probably not available any more. In my case, I'm not concerned about it since I've been using Permatex silicone form-a-gasket for these applications for years. I'm posting this while RiverPatrol is probably still sleeping, since she'll give me a hard time. :twisted:
I have developed an oil leak in the past few days of one of these seals in the transfer case, the output to the rear axle. It's been leaking a lot while sitting. I will try to take some measurements of a spare seal that I have in my stash.
