Clutch Slave needed
- Has thanked: 24 times
- Been thanked: 23 times
Clutch Slave needed
Hi Guys, Need a clutch slave. please let me know if you got one in working condition. If you have a recommendation for a replacement that would be great as well.
Thanks
Thanks
- Has thanked: 173 times
- Been thanked: 306 times
Re: Clutch Slave needed
We use Protex brake cylinders and clutch cylinders here is Oz. They are available on ebay as well as at retail stores. They are good components.
I think however that there are two slave clutch cylinders available for G60s. One for early models and one for later models. I don't know enough about them perhaps others may be able to comment.
- Has thanked: 7718 times
The clutch slave is the same through the series.
- Has thanked: 6022 times
The only minor difference is that since 77 is metric, so might need to pay attention to the line fittings.RiverPatrol wrote:The clutch slave is the same through the series.
- Has thanked: 257 times
- Been thanked: 270 times
That slave cyl works fine. I'm using one on my Patrol because I had it available. (Free)
The bolt spacing of the truck cyl is considerably narrower, necessitating slotting one hole completely to the edge, or milling both holes part way out.
Mild Bill
Mild Bill
