Page 1 of 2
NISSAN PATROL MANUAL
Posted: Wed Jan 14, 2004 4:27 am
by npca-mossy7106
HI COULD ANYBODY HELP ME LOCATE A MANUAL FOR 1983 NISSAN PATROL DIESIL DONT KNOW MUCH ABOUT IT BUT ITS GOT AN SD33 DIESIL ENGINE THANKS MOSSY7106
Posted: Thu Jan 15, 2004 2:40 am
by npca-tommyboy
i have one .what do you need to know? i could scan a page of info for you; tomPost your free ad now! Yahoo! Canada Personals
Posted: Thu Jan 15, 2004 8:25 am
by npca-mossy7106
This message has been deleted by the author.
Posted: Thu Jan 15, 2004 2:24 pm
by npca-tommyboy
1980- 87 are the mq series the tag [vin ] should be located for you on the drivers side inner fender panel it has the model if it's a 2 door it will say kl160 4 door?Post your free ad now! Yahoo! Canada Personals
Posted: Thu Jan 15, 2004 3:37 pm
by npca-frat-boy-1
Mossy:; ; ; I bought an aftermarket manual from a parts supplier in memphis tennessee. just don't have the name on the tip of my tongue..; will write back witn name.; ; ; carl; ; Do you Yahoo!?; Yahoo! Hotjobs: Enter the "Signing Bonus" Sweepstakes
Posted: Thu Jan 15, 2004 4:16 pm
by npca-mossy7106
Posted: Thu Jan 15, 2004 4:39 pm
by npca-fud
You can get most all manuals and a few parts books from here
http://www.schiffeuropean.com./Main_Catalog.html I have bought from them and they are good books. No need to look further as he has what you all have been asking for. Ian
Posted: Fri Mar 19, 2004 11:11 pm
by npca-deceitfulderivative
I have a NISSAN PETROL diesel vehicle. I presume it is 1993 model. I am not very sure because it is a preused vehicle imported by a private party.The Name plate particulars on the vehicle are as follows. TYPE :- Y-WR GY60; Chassiss No.WRGY 60-510603; MODEL :- CRGY60PKTAZ :ENGINE No. TD42-0037777. I want the following information. (1) What model vehicle is this? Whether my presumption that it is a 1993 model Vehicle is correct? (2) Can any body e-mail me the wiring diagram applicable to this model.(3) The coolant is getting over heated even after short journies and the radiator is getting evacuated. How can I remedy this.(4)The vehicle has got auto transmission and I have a feeling that the gears are not shifting when they should. How can I adjust this?(5) There is a sensor for cutting off the A.C Compressor by disconnecting its clutch when the coolant gets over heated. At what temperature should this act. Thanks. Rao.
Posted: Sun Mar 21, 2004 2:40 am
by npca-4x4peter
Hi Rao C = High roof Station Wagon R = TD42 engine (4.2 litre Diesel) G = long wheel base Y60 = Model = Nissan Patrol Y60 series PKTAZ = vehicle serial number 1993 = ???? can't tell from info I have You may find all your problems stem from running to hot. The Nissan GQ Patrol diesel TD42 has does develop overheating problems. 1. The viscus fan unit fails to function properly, either get it recharged with oil or replace. 2. The Fan blade develops radial cracks between blades and distorts so does not move so much air, replace. 3. The transmission oil cooling section of radiator maybe partly blocked put in aftermarket oil cooler and service transmission. 4. Check radiator core is not blocked and get flushed as necessary. 5. Radiator fins blocked (mud/grass etc.) clean out as necessary. 6. If the transmission is overheating chech for mud/grass etc arround transmission which will inhibit cooling air flow. 7. Check correct tension on fan belts. If you are new to four wheeling or just setting up your truck then the TECH HINTS section of my website
http://equip4.co.nz this site is basses arround Nissan patrols in New Zealand. We also have a range of recovery gear along with a gallery and a technical hint section, have a look and if it is of interest to you email me and I will put your name on the Newsletter email list for future updates.Peterequip4.co.nz
Posted: Sun Mar 21, 2004 3:45 am
; ; ; Hi Peter; Thank you verymuch for the information ; furnished.I will be grateful if you can further help with ; any other supplemental information.I give below ; what I have already done.; ; 1) How can I recharge the viscous fan?; 2) The Fan blades are fairly O.K. excepting a ; couple of minor cracks on the hub.; 3) thetransmission oil cooling radiator appers ; to be in good condition.; 4) I opend the radiator and thoroughly cleaned ; up. There are no blockages or leakages.; 5) I have already done this. The vehicle runs on ; city roads and are not blocked.; 6) These areas are clear.; 7) I have already checked but I will recheck ; this again.; ; I will be happy if you can put me on Newsletter ; email list.; Thanks,; Rao.; ; ; ----- Original Message ----From: 4x4peter ; To: Nissan Patrol Club ; Albuquerque ; Sent: Saturday, March 20, 2004 11:40 ; PM; Subject: Re: NISSAN PATROL MANUAL; ; ; ; ; New Message on Nissan Patrol ; Club Albuquerque; ; ; NISSAN ; PATROL MANUAL; ; ; ; Reply; ; ; ; ; ; Reply to Sender Recommend ; Message 9 in ; Discussion ; ; ; ; ; ; From: 4x4peter ; ; ; Hi Rao; ; C = High roof Station Wagon; R = TD42 engine (4.2 litre Diesel); G = long wheel base; Y60 = Model = Nissan Patrol Y60 series; PKTAZ = vehicle serial number; ; 1993 = ???? can't tell from info I have; ; ; You may find all your problems stem from running to hot. ; The Nissan GQ Patrol diesel TD42 has does develop overheating ; problems.; 1. The viscus fan unit fails to function properly, either ; get it recharged with oil or replace.; 2. The Fan blade develops radial cracks between blades and ; distorts so does not move so much air, replace.; 3. The transmission oil cooling section of radiator maybe ; partly blocked put in aftermarket oil cooler and service ; transmission.; 4. Check radiator core is not blocked and get flushed as ; necessary.; 5. Radiator fins blocked (mud/grass etc.) clean out as ; necessary.; 6. If the transmission is overheating chech for mud/grass ; etc arround transmission which will inhibit cooling air ; flow.; 7. Check correct tension on fan belts.; ; If you are new to four wheeling or just setting up your ; truck then the TECH HINTS section of my website
http://equip4.co.nz this ; site is basses arround Nissan patrols in New Zealand. We also ; have a range of recovery gear along with a gallery and a ; technical hint section, have a look and if it is of interest to ; you email me and I will put your name on the Newsletter email ; list for future ; updates.Peterequip4.co.nzView other groups in this ; category.
