Loking for acorn nut for Valve cover , carb stud and wing nut for oilbath cleaner not sure if it is anything special.
Also need the round interior light lens on the dash. Mine is missing . Does anyone know if front windshield is available ?
And a pass side mirror thanks
Need a few parts
- Has thanked: 6030 times
- Been thanked: 1610 times
Re: Need a few parts
There is this reference for the valve cover washers: 13275-F1000. These are the ones with the rubber gasket embedded. The acorn nuts itself are in Standard (SAE) thread, so you might be able to source at specialty hardware stores.
Regarding the windshield, I have the geometry and can send you a PDF drawing of it. I'm sure with the measurements, they can cut the glass for you. You can take this PDF drawing to a print shop. The other route if your windshield is still in one piece (although cracked) is have the glass show use it as a template. They offer to do that for me some years ago, but at the end I got one from member RiverPatrol. Still pending install.
One of the members here used the following profile for the windshield gasket:
https://www.steelerubber.com/master-num ... 60-0728-99
- Been thanked: 1991 times
The ebay supplier from Columbia stocks the rubber seal that fits around the front windshield.
- Has thanked: 264 times
- Been thanked: 776 times
I have an original windshield taking up space in my garage. Not sure how to ship it but it should be doable.
- Has thanked: 3 times
thanks to all that replied and I will check into all of the options that I have been given
