Output shaft seal 1968 Patrol 38189-44000
Original and compatible parts
Post by Shad »
Help....
I can’t locate a replacement seal. Please provide any leads you may have for a replacement or compatible part.
Thanks
Shad
415-250-8093
Has thanked: 81 times
Been thanked: 173 times
Re: Output shaft seal 1968 Patrol 38189-44000
Post by nizmut »
Robin
Post by nizmut »
nizmut wrote:https://www.ebay.com/itm/AVX-Shaft-Oil-Seal-TC50x73x12-Rubber-Lip-50mm-73mm-12mm-metric-/401046258790?hash=item5d60384466
Get at least 4, they fit the pinion input shafts, and both transfer out put shafts.
Robin
Post by Shad »
Thanks Robin - on order
Has thanked: 514 times
Been thanked: 631 times
Post by rdarnell »
They seem a bit snug going in and also on the sealing surface.
Has thanked: 6031 times
Been thanked: 1610 times
rdarnell wrote:They seem a bit snug going in and also on the sealing surface.
Did you measure the actual surfaces? I'm curious since I bought these seals a while back but have not try to install them yet.
posted some side bby side pics of the AVX and NOS Nissan seals in the original thread on this topic:
viewtopic.php?f=24&t=2665&p=46595#p46595
