Marks 5sp help
Been thanked: 4 times
Marks 5sp help
Post by Aus60 »
Hey all, have been making some progress on my KG60 and getting into fiddly bits (will post progress on original post). But I've come into ownership of a marks 5sp attached to a transfer. What else should I need to make this work on my patrol apart from drive shaft extentions?
Greatly appreciate help :)
Has thanked: 173 times
Been thanked: 306 times
Re: Marks 5sp help
Post by Peter60 »
Not too much.
Is it installed? If not you need to look at the clutch and tail shaft.
There are manuals/install instructions for the Marks in this forum somewhere . Try this http://60patrol.com/forum/viewtopic.php?f=32&t=1894.
