Plates for rubber gear boot brackets
- Has thanked: 49 times
- Been thanked: 141 times
I'm not sure how to describe them... There's apparently some kind of bracket that goes around the rubber boots for the parking brake and the 4wd levers. I presume they look like some kind of rectagular donuts with holes in them.
Does anyone have them and willing to part with them? I'm happy to pay for them + shipping.
- Has thanked: 6027 times
- Been thanked: 1607 times
Re: Plates for rubber gear boot brackets
The models with the vinyl boots, including the parking brake, have the plates that go on top and are bolted to the captive nuts underneath. Yours is probably like that. I don't recall what year they changed to the wider cover over the transmission with rubber boots for all the levers.ckhorne wrote:I'm not sure how to describe them... There's apparently some kind of bracket that goes around the rubber boots for the parking brake and the 4wd levers. I presume they look like some kind of rectagular donuts with holes in them.
If you already have the rubber boots, you can modify them slightly on the underside lip (to avoid the captive nuts) and install over the cover without any of the metal plates. I did that on mine (65) years ago.
I have the reproduction rubber boots (sold by anpira83 on ebay). What you're describing would likely be easier... do you have a picture of your setup?Esteban wrote:If you already have the rubber boots, you can modify them slightly on the underside lip (to avoid the captive nuts) and install over the cover without any of the metal plates. I did that on mine (65) years ago.
I will take a picture tomorrow.
Here are two pictures of the rubber boot for the 4wd and H/L shifters. The hole in the cover is roughly the same as in later models that came with the rubber boots standard.
In the following photo you can see that I didn't cut the underneath lip to clear the captive nuts, since all were removed. I put some duct tape to cover the holes and prevent fumes from coming in.
It is possible that you might need to fix somehow the rubber boot to the cover. The boots on mine (except the transmission shifter one) are original from Nissan. The aftermarket ones are not as flexible. I once tried them some 20 years ago, and it was specially a problem with the parking brake boot, that lifted from one side of the cover every time that it was engaged.
The boot for the shifter is from a Mazda or Ford Courier pickup truck. It is hold with tape to the cover since there's no other choice. Since on top I have a carpet felt and then carpet, you don't ever see the redneck solution.
Thanks for taking the pictures - that's somewhat what I had in mind when you said that, but that helps visualize it.
I'm not sure if I have enough material there to be able to do that with, but I'll give it a try. I'm in the middle of a restoration, so I'm not sure I'm willing to use duct tape to fill in the gap.... I'll play with it and see what I can come up with.
Thanks!
Thanks!
- Been thanked: 1991 times
Ebay seller from Columbia named anapira83 can make them for you if you have the same boots as I have in my 63 and 65s.
He is a good guy, I've used him many times.
Patrolling for parts,
- Has thanked: 203 times
- Been thanked: 681 times
Are these the plates/brackets being discussed in this tread?
Keith
- Has thanked: 7741 times
- Been thanked: 2482 times
Yes, the lower half. There is an upper half that is kind of beveled.
