Is there a suitable replacement for the hood bump stop? I think there are 6 of them that push into holes on the underside of the hood where it meets the fender.
Thanks!
Hood Bump Stops
- Has thanked: 7718 times
- Has thanked: 131 times
- Been thanked: 147 times
Re: Hood Bump Stops
If you are referring to the all rubber stem bumpers that push into the holes on the bottom flange of the hood, I used these from Steele Rubber Products:
https://www.steelerubber.com/gravel-shi ... 33-0016-45 They fit in a 3/8" hole. They also worked great on the bottom of the rear jump seats where the seats rest on the rear wheel wells.
This was on a true 69' model. Not sure if they would be the same for earlier years.
Re: Hood Bump Stops
Cool! I've added this to the compatible parts list.
- Has thanked: 23 times
- Been thanked: 57 times
Re: Hood Bump Stops
I bought a mix of bumpers on amazon, so I'll report on those as well.
Thanks!
Thanks!
Located in central Missouri
1966 Hardtop
1964 very modified Hardtop
1967 Parts
1968 Parts
1962 Softy - SOLD
1966 Hardtop
1967 Parts
1968 Parts
1962 Softy - SOLD
Re: Hood Bump Stops
The amazon ones didn't work so I ordered the Steele ones. Thanks for the recommendation!
1966 Hardtop
1967 Parts
1968 Parts
1962 Softy - SOLD
1966 Hardtop
1967 Parts
1968 Parts
1962 Softy - SOLD
