Will this work for my 1964 Patrol?
Original and compatible parts
Been thanked: 37 times
Post by Volkmann77 »
https://www.ebay.com/itm/OEM-QUALITY-Br ... rk:20:pf:0 I am missing my master cylinder and was curious if this part is compatible. :(
Has thanked: 7706 times
Re: Will this work for my 1964 Patrol?
With modifications, yes. And it is probably your easiest option, since the original master cylinder is unavailable. The original system was a single circuit, the listing is a dual circuit. You will need to run some new brake line to split front to rear, and as I recall might need a proportioning valve. There are discussions here regarding this, a search will bring up several.
Yes I searched but, got lost in the sea of info.
Has thanked: 6018 times
A couple of members have installed a Wilwood master cylinder. I saved the reference just in case.
https://www.wilwood.com/mastercylinders ... o=260-8794
In both cases you have to modify the lines like RiverPatrol mentioned, but the Wilwood has standard threads for the lines instead of metric, so one less problem.
If you search "Wilwood" here you'll find some additional notes.
Thanks. I gotta get the brakes sorted out and looking for the easiest method of dealing with it.
Has thanked: 264 times
Been thanked: 776 times
Post by plateaucal »
Here is the thread on master cylinder install that I did. I am pleased with the results.
http://60patrol.com/forum/viewtopic.php?f=24&t=3529
