INDEX(mostly for myself to minimize searching all pages)
Page#
1 parts trucks and trans teardown
3 trans seal and bearing part numbers
4 transfer case seal and bearing part numbers
5 front disc brake conversion ... see modifications section for more details on build
7 engine disassembly and engine kit invoice with part numbers
9 engine build with pdf of TCM PPU240 engine manual, I also post a copy of the manual in the manuals section
11 front and rear axle reinstalls
16 hubcap modification for use on Land Cruiser rims
17 oil filter and distributor differences over the years
18 land rover rear taillights and remove wood dash to start dash wiring
19 repair dash wiring and chase wires to test all circuits
20 turn signals and wiper motors
21 warn hubs and mock up rear disc brake, possible replacement heater core
22 rear disc brake build, also in the modifications area
23 make brake lines and booster mount
24 short block engine install
25 clutch comparisons and install
26 install head / adjust valves and mount oil filter adapter
27 rochester carb comparison
