Water temp sender
- Has thanked: 16 times
- Been thanked: 57 times
Water temp sender
Does anyone know the correct size screw to hold the wire onto the water temp sender unit? I lost mine into the bowels of the engine bay, and no amount of searching can find it. I know it is a small brass screw, but that's all I could remember as it dropped into the void!!! I even swept the floor, but it remains lost.
- Has thanked: 6031 times
- Been thanked: 1610 times
Re: Water temp sender
What year is yours, since there's two types of the temperature sender. Mine is a 65 I can check tomorrow morning. Hope I don't loose it
Thank you. Mine is a Feb 1978 build. Yeah, don't loose it, they are tiny!!! Had it been metal it would have stuck to the tip of the screwdriver.
- Has thanked: 7750 times
- Been thanked: 2483 times
Yours is probably metric then. Esteban's wouldn't be.
RiverPatrol is right. Mine came from a 74 that was still in SAE. After 78 everything turned to metric.RiverPatrol wrote:Yours is probably metric then. Esteban's wouldn't be.
However, an educated guest after checking the one that I have, is that you probably need a M3 with the standard pitch of 0.5mm. From what I see, you have only another choice, and that will be an M3 with a 0.35mm pitch.
M3x0.5
M3x0.35
I will buy the two options, and the lenght should be no more than 10mm. Probably 8mm will be ok.
Let us know what you find.
- Been thanked: 1991 times
Esteban, Please include your source too. I need one as well.
Thank you,
Thank you,
- Has thanked: 97 times
- Been thanked: 568 times
I think I have a spare one of these at the house. I can check and see when I get back home. I could also check to see what the screw size is.L60Boerne wrote:Esteban, Please include your source too. I need one as well.
Thank you,
Thanks Justin.
David, I haven't purchased anything. Was just doing a guess for the scree that member ozscott needs, since his is metric.L60Boerne wrote:Esteban, Please include your source too. I need one as well.
Thank you,
Your best bet will be jwgreen. Hope he can check the correct screw for the USA Patrols.
Thank you Esteban.
