1967 Gauge Panel
zed
Has thanked: 201 times
Been thanked: 677 times
1967 Gauge Panel
Post by zed »
The consensus is this gauge panel is from a 1967 Patrol.
So my question is.....Which of any of the gauges, switches, or lights are compatible with other year Patrols?
7304
7305
Thanks,
Keith
Has thanked: 7693 times
Re: 1967 Gauge Panel
'67 was the first year that had the gauge regulator. The gauge regulator is for the temp and fuel gauge as I recall. Plateaucal can correct me on that if necessary. Since the oil pressure gauge has the push on blade connectors that started in '67 those three gauges can only be used in '67 and later applications. The amp gauge can possibly be used in earlier models.
Has thanked: 264 times
Been thanked: 776 times
Post by plateaucal »
Ms. River. How the heck are you doing? I just got a bottle of Colorado Absinthe from the guy that actually makes it. Dang. So, since I cannot give it away, I will search down a source. Yes you are right on the gauge regulator. I don't know what year it began but it should be obvious. The gauge regulator is a simple little mechanism and I had a fun afternoon making it work again. We may need to start a thread on gauges, because it is confusing.
plateaucal wrote:Ms. River. How the heck are you doing? I just got a bottle of Colorado Absinthe from the guy that actually makes it. Dang. So, since I cannot give it away, I will search down a source. Yes you are right on the gauge regulator. I don't know what year it began but it should be obvious. The gauge regulator is a simple little mechanism and I had a fun afternoon making it work again. We may need to start a thread on gauges, because it is confusing.
Colorado absinthe? Yes please! :mrgreen:
zed wrote:The consensus is this gauge panel is from a 1967 Patrol.
Thanks,
Keith
Keith - remind me again why the consensus says this is from a '67?
zed
Post by zed »
Leslie,
See posts
Fri Sep 18, 2020 3:31 pm
Fri Sep 18, 2020 4:32 pm
viewtopic.php?f=17&t=5907
Regards,
Keith
Thank you for refreshing my memory. I stated then that I thought it was for a '68, this is why I was confused seeing you say consensus says '67. I still say '68. The reason I say that is because it doesn't have the push button for the starter, instead it has a windshield washer switch in that location. '68 was the first year for washers so the switch was there. '69 went to the new style wipers so the switch became a wiper/washer switch.
zed
Post by zed »
Leslie,
I attributed the consensus partially on your statement "Maybe '67 but I think that style headlight switch didn't come out until '68".
I did not want to represent the applicable year.
Keith
Thanks Keith.
Back to your original question:
zed wrote:Which of any of the gauges, switches, or lights are compatible with other year Patrols?
The speedo will work back to early '66 when the speedo cable and adapter changed.
The oil gauge and ammeter will work on any year.
The fuel and temp gauge will work on '67 and later.
The ignition switch will work on '68 and later.
The headlight switch will work on '68 and later.
The windshield washer switch will work on '68 only.
The turn signal and high beam indicator will work on '68 and earlier.
zed
Post by zed »
Thorough and comprehensive, thanks Keith
