P40 Distributor
Been thanked: 5 times
P40 Distributor
Post by kuzzen »
The distributor for my 1969 Patrol is missing the keyed shaft on the bottom end that fits inside the engine. Willing to purchase that piece or a complete distributor...thanks.
Re: P40 Distributor
Kuzzen, RiverPatrol included yesterday a link for a new distributor.
viewtopic.php?f=20&t=4868&p=48677&hilit=forklift+distributor#p48677
In addition, Helmar has the distributor also, since it was fitted on Komatsu forklifts that used the P and the P40 engine.
https://www.helmarparts.com/22100-C7000 ... -c7000.htm
Please note that this is the standard distributor, not the water-protect one that came as original equipment in the USA models. And a final note, all Patrols up to 1978 or 1979 are fitted with the P engine (this is what you have) The P40 is a small evolution of the P. Among the changes done:
- Timing chain instead of timing gears
- Crankshaft bearings (#1 bearing had a redesign and therefore is not interchangeable)
- Intake and Exhaust manifolds
- Carburetor
- Cam followers
- Oil filter
- Water Pump and Thermostat housing
