1969 Nissan Patrol - For Sale in Sacramento, CA $16,800
Posted: Thu Aug 26, 2021 4:15 pm
by ckeene
This Patrol has been in our family since the early 1980s. This Patrol was restored in 2017-2018. List of work done below.
Low miles (42,438)
Manual transmission with three speeds.
Here is a list (from our mechanic) of work done:
REPAIR BODY
RE MANUFACTURE TWO REAR DOORS
PAINT COMPLETE VEHICLE
REFINISH INTERIOR DOOR PANELS
REBUILD SEAT FRAMES
NEUTRALIZE RUST IN SEAT FRAMES
UPHOLSTERY SEATS
PURCHASE AND INSTALL NEW SEAT BELTS
PURCHASE AND INSTALL ROLL BAR
CUSTOM INSTALL STYLE BAR FOR SEAT BELTS TO MOUNT ON
DRAIN AND REPLACE FLUIDS
REMOVE FUEL TANK
HOT TANK AND LINE FUEL TANK
REPLACE NECESSARY FUEL LINE
REBUILD CARB
REBUILD WATER PUMP SEALS AND BEARINGS
CLEAN AND REPLACE PARTS IN DISTRIBUTOR
NEW CAP AND PLUG WIRES
NEW SPARK PLUGS PERFORM COMPRESSION TEST
REMOVE RADIATOR SENT OFF TO BE REBUILT
REMOVE WHEELS AND TIRES PAINTED WHEELS AND NEW TIRES
NEUTRALIZE RUST INTERIOR FLOOR PAND
CHECK AND REPLACE BAD WIRING ENGINE COMPARTMENT AND UNDER DASH
REMOVE FUSES AND CLEAN FUSE PANEL
SENT OFF BRAKE SHOES TO HAVE NEW LININGS PUT ON
INSTALLED ALL NEW BRAKE WHEEL CYLINDERS
INSTALLED ALL NEW BRAKE PADS
TURNED DRUMS ALL FOUR
REPLACED MASTER CYLINDER
RE PLUMB BRAKE LINES TO NEW MASTER CYLINDER
REBUILD CLUTCH MASTER AND SLAVE CYLINDER
This forum limits size/resolution of pictures. If you want more pics or better quality, please message me. Thanks!
Re: 1969 Nissan Patrol - For Sale in Sacramento, CA $16,800
Posted: Thu Aug 26, 2021 6:06 pm
Looks and sounds like a fun Patrol. Good luck with the sale!
