L60 Carb Adjustment Qs
Has thanked: 48 times
Been thanked: 149 times
Post by Slackd »
I’ve read all the posts I could find on carb adjustments, but still not certain how to proceed, and not even sure what carb I have installed.
Photos below of my ‘69 L60 carb. Only two adjustments accessible from outside. Idle speed and fuel/air mixture. Current timing is ~10° before TDC. I have many of the same issues others have had: backfiring, stumble at low RPM, engine dies when coming to a stop. Also, crazy bad fuel mileage.
Any/all suggestions welcome.
Thanks
Dave
Has thanked: 264 times
Been thanked: 776 times
Re: L60 Carb Adjustment Qs
Post by plateaucal »
Fuel level would be a thing. My throttle response cleared up after a valve adjustment. My take.
Any other thoughts?
Has thanked: 7700 times
Been thanked: 2478 times
That is the stock Rochester carb. It sounds like it needs rebuilding, the accelerator pump in it is probably bad. It a GM carb so any competent carb shop should be able to do it.
Post by Slackd »
Thanks RiverPatrol. Q: how do I thank someone through the site without adding a new post?
In the post that you want to thank the user for there should be a thumbs up icon in the upper right corner. Just click that. I have had some users say the icon isn't there occasionally.
Been thanked: 1987 times
My advice is that before you spend too much money on the old Rochester carb consider putting it on the shelf. In my experience it is worst of all Patrol carbs. There is a modern NAPA clone described here in the forum that is much much better than any of the vintage carbs....in my somewhat experienced opinion.
Patrolling again soon,
Has thanked: 455 times
Been thanked: 790 times
Post by r1lark »
RiverPatrol wrote:In the post that you want to thank the user for there should be a thumbs up icon in the upper right corner. Just click that. I have had some users say the icon isn't there occasionally.
Right now, the thumbs up icon isn't appearing for me either. This just started, since I used it a couple of days ago. :?:
Post by Slackd »
Searching for NAPA replacement carb (ND 1495) shows not available. I’ve contacted National Carburetors in Jacksonville for a rebuild of my Rochester B @ approx $200. Not sure what other options are out there.
Has thanked: 6013 times
Slackd wrote:Searching for NAPA replacement carb (ND 1495) shows not available. I’ve contacted National Carburetors in Jacksonville for a rebuild of my Rochester B @ approx $200. Not sure what other options are out there.
There's this one at Amazon. Way cheaper and better solution than a rebuild. There are many other similar choices there.
https://www.amazon.com/Partol-Carbureto ... NB88J?th=1
This carburetor is a knockoff of a Carter YFA. I been running the Carter one for 16 years on mine, and was previously fitted to another Patrol for 10 years. Came originally from a 6 cyl Bronco, 1980 model. I took apart the automatic choke and replaced with a kit for a manual one.
A minor mod needs to be done for the linkage. Keep the following link handy just in case.
AED Performance 5425 - AED Throttle Lever Stud Kits
https://www.summitracing.com/parts/aed-5425
:think: It's a mystery to me.
