Wix oil filter replacement
Has thanked: 48 times
Been thanked: 151 times
Post by Slackd »
Help, again. Please. Replacing oil filter with new Wix filter. New filter came with three different sized o rings. Am I looking for the one that fits outside the filter housing, below the housing into the housing groove or inside the housing? I did not remove an o ring when I removed oil filter housing and old filter. Weird?
Thanks. Everyday is a an adventure.
Dave
Has thanked: 7706 times
Re: Wix oil filter replacement
There is an o ring in that groove, if there wasn't your oil filter housing would have been leaking badly. It usually requires digging the old one out, it's pretty deep in there.
Post by Slackd »
Yes, you are right, as always. On further inspection I was able to dig the old one out and replace with new one. All good now.
Thank you.
Dave
Has thanked: 6018 times
You have 3 O-rings, pictured below:
#3 At the top, outside the canister
#8 Goes in Washer/Retainer #9. This is crucial. Without it the oil is not filtered!
#4 Goes in the groove of the main body, where the canister sits.
From what I remembered the oil filters came with #8 & #4 only.
Has thanked: 22 times
Been thanked: 113 times
Post by desertrat »
Esteban wrote:You have 3 O-rings, pictured below:
Don't forget 3 and 8. I don't think they are included with the Wix currently. They are inch size o-rings that you can match up from the common o-ring kits available. Next time I do a filter change I will note the sizes if these o-rings and post them for future reference.
Has thanked: 455 times
Been thanked: 791 times
Post by r1lark »
I know this is an old thread, but in case others in the future are searching for the oil filter seals ("O-rings")..........
Nissan still stocks the factory original oil filter for our Patrols as of May 2022, and it includes all three of the required and correct seals! The p/n is 15208-32225.
Here are some pics:'
Been thanked: 13 times
Post by dmo67patrol »
Hi there,
Do you happen to have the oil cannister replacement number from WIX?
thank you,
dmo
