Stumped on fuel to bowl
Has thanked: 233 times
Been thanked: 165 times
Post by pdub »
Help! Can’t figure this problem out. The fuel filter bowl is not filling when engine is running, At idle it stays at just under half full. You can see the fuel dribbling down the side of the bowl to fill it but it doesn’t fill up. I just replaced the fuel pump thinking that would pull more fuel but no. My only thought is a leak somewhere in the line to the tank sucking air but there is no fuel leak. Anyone ?
1967 Patrol
2017 Toyota Tacoma
1968 Camaro
1968 Disneyland Autopia Car
Has thanked: 173 times
Been thanked: 306 times
Re: Stumped on fuel to bowl
Post by Peter60 »
I just have a small see through filter before my fuel pump. I don't have a bowl. The fuel pump has been rebuilt.
The small filter NEVER seems to fill up, its often just a third full.
However the Patrol seems to run OK. I have travelled several 1000 KMS at highway speeds.
I'd be interested in the responses to your question, to see if it applies to me.
Has thanked: 7687 times
:text-yeahthat: I'm thinking the same. My soft top has the glass full bowl and I don't recall ever seeing it fill up all the way. Runs fine.
