manual starting rod....1967 L-60
Been thanked: 1 time
Post by hoyt »
would like to buy a manual starting rod which slips in the grill to engage crank pulley to turn over motor
in case....say...your starter stops working......ive read it also serves as the jack handle...?
Re: manual starting rod....1967 L-60
I've heard that the Land Rover crank start handle interchanges with the Nissan Patrol... but considering I've never seen a Land Rover handle, take that with a grain of salt!
However, it;s a pretty simple design so it would be really easy to copy. I posted pics and measurements on it here:
viewtopic.php?p=19126#p19126
Good luck!
Has thanked: 7716 times
The Land Rover one looks similar, I don't know that actual measurements. https://www.roversnorth.com/parts/pla95 ... ia_and_iii
The jack handle was a separate item.
Has thanked: 455 times
Been thanked: 791 times
Post by r1lark »
RiverPatrol wrote:The Land Rover one looks similar, I don't know that actual measurements. https://www.roversnorth.com/parts/pla95 ... ia_and_iii
I purchased one of these hand cranks from Rovers North. It seems well made. I did need to cut off about 1/8 to 3/16" off the end so the pin engaged fully into the 'receiver' part on the crankshaft hub.
Has thanked: 264 times
Been thanked: 776 times
Post by plateaucal »
If someone would post a photo with dimensions, one could be fabricated in an evening with a torch, a drill and a welder.
plateaucal wrote:If someone would post a photo with dimensions, one could be fabricated in an evening with a torch, a drill and a welder.
BOOM! Who would have guessed that everything you need to patrol your Patrol would be at this little forum.
Been thanked: 21 times
Post by Mr. Zero »
I believe that I have a spare, including the original mounting blocks, that I'm willing to part with. Let me know if you're still looking for one.
Jason @battlebornpinzgauer
[1975 Pinzgauer 710K 2.7L EFI]
Post by hoyt »
Mr. Zero wrote:I believe that I have a spare, including the original mounting blocks, that I'm willing to part with. Let me know if you're still looking for one.
hello.....do you still have crank rod....and mounting blocks? .if so how much you need to get it to 50595-1747.......iowa
Post by Mr. Zero »
hoyt wrote:
Mr. Zero wrote: hello.....do you still have crank rod....and mounting blocks? .if so how much you need to get it to 50595-1747.......iowa
This has suddenly become a hot topic. A few folks here have expressed interest in just the last couple of days. Please PM me. Sale pending, but if that falls through, you're next in line.
