Oil System Priming Shaft - Dimensions Needed
Has thanked: 455 times
Been thanked: 789 times
Post by r1lark »
Need some help fellow Patrolers.
Early next week I'm taking a trip to work on my Patrol, which is about 90 minutes away. Oil & filter change, and priming the oil system is on the agenda. I want to make a priming shaft to go in place of the distributor drive spindle. Spent about an hour searching old posts and can't find the info I need (but did find important info like the pump has to turn CCW).
Plans are to use a 5/16" or 3/8" carbon steel rod, and grind the tang on the end that will engage the oil pump. Will use a battery powered drill to drive the pump. I need to make the priming shaft here at home and need some help on dimensions.
Questions:
1) Anyone know the diameter of the distributor drive spindle? I'm not trying to match the shaft diameter, but wanted to make sure I don't go to big on the priming shaft diameter.
1) What would be a reasonable approximate overall length to make the priming shaft?
2) What is a reasonable thickness (dimension "a" in the pic posted below) for the tang, with the understanding I'm not making a new shaft so it doesn't need to be exact. I just don't want to end up with too thick a tang that won't fit into the oil pump.
Thanks in advance for any input!
Has thanked: 149 times
Been thanked: 310 times
Re: Oil System Priming Shaft - Dimensions Needed
Post by G60michael »
G'day mate, I've had a lot of G60s, Some that have Sat Idle in paddocks for a Decade or Several Decades, When I've Primed them up I Just Used a Cheep or Old Long Larger Flat Blade Screw Driver, With the See-Through Yellow Or other Colored Handle, Just Use a Hammer and Bash the Handle till it breaks apart then slip the Screw Driver Shank into the Drill and Spin it Anti-Clockwise, works well everytime for me.
Hope this Helps Mate, Cheers Mick
Has thanked: 42 times
Been thanked: 247 times
Post by Johnny Roadkill »
Not trying to talk you out of making a proper tool if that's a project you want, but I still have the 12" length of 3/16" rod with a bit of steel scrap wire-wrapped to one end I made 30 years ago for Datsun L series motor oil priming...would probably work on a P motor too...
...but if I were doing it over I'd use G60michael's screwdriver idea - $5 from Hammerbarn and much more elegant !
Cheers,
D
Post by r1lark »
Thanks for the feedback guys! All my flat blade screwdrivers are square stock, so that won't chuck up too well in the drill. :D
I've already got some round rod left over from something else, and realized I can take my battery powered 4-1/2 " angle grinder with me and use that to make the shaft to fit. Love these battery powered tools!
