Air line routing between air filter housing and distributor
zed
Has thanked: 202 times
Been thanked: 678 times
Post by zed »
Can anyone provide a routing diagram for the two air lines that connect the air filter housing and distributor.
Items #2 in
Photo courtesy of RiverPatrol "Lou's '69"
Thanks,
Keith
Has thanked: 455 times
Been thanked: 789 times
Re: Air line routing between air filter housing and distribu
Post by r1lark »
Keith, here are two pics that might help. The two air lines, plus the vacuum advance line, follow along together behind the thermostat housing. I don't have a pic of how they are routed on the other side of the rocker cover, but could get some pics of that late next week if you need those -- just let me know.
zed
Post by zed »
r1lark,
Thank you so much. Photos of the other side would be very much appreciated.
Keith
zed
Post by zed »
The two lines I have (sourced from a member who required talocrural region adjustment) has the following specs:
Air line O/D: 5/32”
One line appears to be steel, one line appears to be copper.
Were both lines originally the same metal?
Keith
Has thanked: 7696 times
Been thanked: 2477 times
I never cleaned them up to notice. :confusion-shrug:
Post by r1lark »
Keith, took pictures today. In the last two pictures, the line I'm pointing to on the distributor is the same line I'm pointing to on the air cleaner.
zed
Post by zed »
r1lark, thank you so much.
RP, :D :D :D :D
Keith
Has thanked: 17 times
Been thanked: 32 times
Post by Frio Patrol »
Upon starting on the long "fix it" list I noticed that the air lines were both cut! I suppose I can have these made? Or is there another alternative?
It looks like someone cut them but left them in place. You could repair the line with a short piece of vacuum hose. Unpinch the end of the lines where they cut. Make sure the other ends are connected at the air cleaner and carb.
zed
Post by zed »
RiverPatrol wrote:It looks like someone cut them but left them in place. You could repair the line with a short piece of vacuum hose. Unpinch the end of the lines where they cut. Make sure the other ends are connected at the air cleaner and carb.
Great idea!!!
Keith
