What is this lever for and fuel tank advice needed please
Posted: Wed Nov 15, 2023 7:02 pm
Hello collective wisdom forum! I'm finally making some headway on this beast. Dropped the tank today. Varnished up something fierce. So what's the verdict, have it cleaned and reuse or get something aftermarket? Also, I am going to replace the fuel line from engine to tank. Can I use rubber hose as long as I secure it or should I use hard-lines in areas? I live in Wisconsin, pretty mild Summers. It will not be driven in the winter.
Also, in viewing the bottom passenger side of the transfer case, I appear to have a lever / linkage that isn't hooked up to anything? (see pic) Is this normal?
Thanks in advance! david
