Wanted Tie rod adjusting sleeve
Has thanked: 1 time
Been thanked: 9 times
Post by Slowtech »
Hi, does anyone have a lead on a Tie Rod adjusting coupler?
The threads are 13/16 - 18
There is a Left-hand thread on one side and a Right-hand thread on the other side.
Thanks in advance.
-shawn
Has thanked: 173 times
Been thanked: 306 times
Re: Wanted Tie rod adjusting sleeve
Post by Peter60 »
New are available on eBay Australia
See https://www.ebay.com.au/itm/234775579172
They look like they should fit, however I have never purchased any.
Has thanked: 1 time
Post by Slowtech »
Peter, thank you. I just sent them a message.
Post by Peter60 »
If you have problems with them just let me know. I'm sure I can assist.
Has thanked: 6017 times
I have my doubts about the tie rods on that link. In the Patrol, one end is short like those, and the other is very long,
Has thanked: 1 time
Post by Slowtech »
Update, I spoke to the folks on that EBay page and they were just listing cars to list cars and it doesn’t fit.
I found out that a select number of trucks and farming combines including the international scout 80, also used a 13/16-18 pitch adjusting nut. However any of the LH threads are UnObtainium.
I ended up getting a tap for the RH thread and then getting some help and Single pointing the LH thread as the only source for. 13/16-18 Left Hand threading tap would have to custom make the tap.
We ended up making the connector out of high carbon prestressed material.
This will get some never-cease when I reinstall.
Excellent fix. Congratulations! :clap: :clap: :clap:
Has thanked: 1 time
Post by Slowtech »
Thanks Esteban!
