Ignition coil
Been thanked: 4 times
Ignition coil
Post by Dave60 »
I have a 69 g 60 Patrol I have no spark and suspect the coil there are no markings on the coil itself, the bracket has 12 v C1Z -18 stamped on it. I'm not having much luck finding it, Please help
Thanks
Dave60
Been thanked: 1981 times
Re: Ignition coil
There are plenty. Very very easy easy to fine, Be sure to get one with an internal capcapsitor in it,
Has thanked: 7689 times
Re: Ignition coil
Re: Ignition coil
The Patrol ignition coil doesn't use a resistor, internal or external.
The coil number for the Patrol is 22433-14806
With that you can find at Rockauto the following using the search function or just the following link:
https://www.rockauto.com/en/partsearch/ ... 2433-14806
A number of options appear. I'll chose the NGK brand.
NGK 48863 NGK Canister (Oil Filled) Coil
Re: Ignition coil
Esteban, You are right. They will run either way but we have found they run cooler with one….thus seem to last longer.
Rolling and Patrolling,
